It is currently February 24th, 2018, 1:28 pm
Post new topic Reply to topic  [ 12 posts ]  Go to page Previous  1, 2
PostPosted: January 26th, 2018, 12:02 am
Isn't it hard on the starter motor and engine to start it everyday and not running it for extends amount of time?
PostPosted: January 26th, 2018, 12:17 pm
Kev,
Sounds like a leaking check valve. If you go to ignition position two, you'll hear the fuel pump cycle for a couple seconds. Do that a couple times before cranking. Might help. Good luck!
