It is currently January 19th, 2018, 11:34 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: vinyl flooring
PostPosted: October 26th, 2017, 11:50 am
Hi Aikensb - Dynamat is a sound and heat insulating product that has foil over a layer of what appears to be rubber and is a peel-n-stick product. I had my engine doghouse and cab lined with it when they installed new carpet and am going to use it to quiet down the generator box (hopefully). Its not cheap but it is very effective in reducing noise.
PostPosted: October 30th, 2017, 7:18 am
Thanks, good to know about this product!
PostPosted: November 2nd, 2017, 10:24 am
Hum, so the wood floor in mine is not original? We love the ease of cleaning it.
PostPosted: November 2nd, 2017, 10:40 am
I can't think of a single Chinook (at least the 21-footers) that came with a wood floor. Most were 100% carpet, and some later ones had an optional tile floor section in the kitchen/entry (but still carpet in the living area). May be different for the newer models with slides and etc. -- I'm not as familiar with those.
PostPosted: November 3rd, 2017, 4:13 am
I thought our floor was origional
PostPosted: November 3rd, 2017, 8:07 am
Looks great. But I don't think it is original. That's not a bad thing though!
(If you want to see the original flooring, you can try looking at the tops of the wheelwells or underneath the shower pan. Places like that. Maybe someone would re-floor the tops of the wheelwells, but few would remove the shower enclosure. Basically, the whole (empty) flat floor was "floored" before the shower enclosure or any of the cabinetry went in. Typically, too, the cab carpet matches (was done by Chinook not Ford).
