Defeating the Low Voltage Cut off switch.
Stan Watkins
Re: Defeating the Low Voltage Cut off switch.
Post by Stan Watkins »
Thanks
1999 Concourse Ford E350
Stan Watkins wrote: February 19th, 2021, 10:02 am . I just want to bypass the LVD for reasons stated.
BTW, did you check the 15A resettable breaker under the rig where the red SENSE wire connects to?
Well, if you do not want to investigate about anything, then you can connect the blue wire terminal (labeled O/R, for over ride, in some of the documentation) to ground (white wire). Please confirm with the documention on the Reference section since I am going from memory. It is strongly suggested by the manufacter not to do that for obvious reason, but if it helps with your marriage, then you can do this.
(Edited to removed incorrect info)
Stan Watkins
Thanks so much. Your help is greatly appreciated.
