I believe I ended up just around 2" with the benefit of all new springs/shocks/hardware for under $2000.
Here is a picture of my rig with the MOOG Front and General Spring Rear leafs installed. Tires in picture are 235/85R16 front and 215/85R16 Rear. Plenty of room for 235's in rear.
Low Cost Suspension Lift
Re: Low Cost Suspension Lift
Here is a picture I found of a Chinook with the ActiveVan 4" LIft.
Bill, are these the springs you ordered?
https://www.generalspringkc.com/product ... 085shd.htm
43-1085SHD
"1992 - 2015 FORD E250 / E350 REAR LEAF SPRING, 10 LEAVES, 5000 LBS CAPACITY"
How did you specify the lift amount?
43-1085SHD
Yes, those are the springs. They only come in one size. Call out to them, they are very helpful and set you up with everything you need shackles, bolts, etc.
Edit: Double post
Last edited by 2Kconcourse on November 24th, 2019, 8:43 pm, edited 1 time in total.
2000 Concourse Club Lounge
I am planning to do the Moog coil springs, General Leaf Springs, and Fox shocks as outlined here on our "new" Chinook that we are picking up tomorrow. So far I have been able to find everything except I wanted to verify if any specific
Fox shocks or custom valving was done on your install?
Also is your 1997 a 460 or V10?
Did you keep the Mor Ryde?
Thanks!
Bryon
Edit: Clarified questions
Thanks!
Bryon
Everyone still happy with this lift approach? Everyone aligned after settling? Was the 2" gain inclusive of the extra gained from taller tires, or was that just for the suspension? And, lastly, was the $2k including labor, or parts only? If the latter, mind sharing about what you paid for installation? I tackle most jobs, but this one would probably frustrate me, especially hearing stories about the front left shock. As I age, I try to pick my battles wisely.
2001 Premier aka "Anookie"
Dallas, TX area
Dallas, TX area
