The trim around the opening to the bath is pretty brittle and cracked, it is white plastic blocked "U" shaped. Anyone know where to get this?
Thanks
Bath entrance plastic trim
Re: Bath entrance plastic trim
The search function for the forum is not working again, but I was able to find the following thread that has the info:
viewtopic.php?t=648
The forum has a wealth of information, but if the search function is not working, it can be hard to dig up gems from the past.
viewtopic.php?t=648
Chin, this was perfect thanks. I thought it was odd I wasn't getting responses from my searches, hopefully it gets corrected soon as there is a wealth of information buried in this site.chin_k wrote: ↑July 17th, 2022, 7:22 pm The search function for the forum is not working again, but I was able to find the following thread that has the info:
viewtopic.php?t=648
I hope Manitou will fix the issue. It is like having a big checking account, but the ATM only let you withdrawn $20 per day.
I found that you can google specific subjects using Chinook RV, etc in search terms...then find links among the results,to discussions in this forum.
Sometimes the other results give good information, too.
Roly
Roly
1998 Premier
Yes, Manitou mentioned that too, so it is a good alternative for the mean time. Just sad to see the information on this site is as difficult to look for sometimes, and it is like a gold mine!
