Full winterization really necessary?
Re: Full winterization really necessary?
If you're going to be in really cold temps, you might open the compartment in back, remove the wood enclosure (at least on my Concourse), which gives you access to the few inches between the bottom of the bathroom and the flooring. I found that the hole in the floor for the toilet pipe down into the black tank had about a half inch open all around it. When in very cold weather (teens or lower), the temperature differential had that very cold air blowing into the back area behind the shower at a decent clip. I plugged that up and it is noticeably better now. I opened up under the sink years ago, and removed the internal shore cable setup for an outlet and separate cable for shore access, so under my sink is wide open to around behind the shower, where the pipes go. Keeping everything open that way keeps my pipes, so far , from freezing. Oh, and bathroom door, like SMan does.
Funny you should mention this. I had the same issue, and I found this is where the mice were getting in. I stuffed the gap with steel wool and caulked it in and sealed it. Made a huge difference.BobW9 wrote: ↑December 5th, 2022, 5:58 pm I found that the hole in the floor for the toilet pipe down into the black tank had about a half inch open all around it. When in very cold weather (teens or lower), the temperature differential had that very cold air blowing into the back area behind the shower at a decent clip. I plugged that up and it is noticeably better now.
