New PD 4645 upgrade
New PD 4645 upgrade
Finally got around to installing the Progressive Dynamics 4645 converter replacing the original Magnatek. It was pretty strait forward. Thanks to Clay for warning about the extra length needed for the primary wire. It was a little different than his scenario of my Premier. I had a nest of wires with cable protectors that need some "massaging" under the kitchen drawers but after that no major issues.
The pictures on the supplied installation sheet were OK but found better ones on Amazon under the reviews. If the new circuit board was 1/8th inch narrower it would have also made installation easier. Two minor issues however.
