I just discovered my camper (living quarters) Kenwood radio only runs off of the engine battery and not the camper batteries, is this normal? This is probably the parasitic load that caused me to put a kill switch on my engine battery. My TV works off the camper batteries and pulls 4.0ah or 48wh, but for some reason the radio is tied into the engine battery, not sure why this makes sense.
Did Chinook install the camper radio to run off the engine battery but leave the TV on the camper battery bank? Or do you think this was owner change for some odd reason.chin_k wrote: ↑August 29th, 2023, 8:49 pm You may want to start a separate thread...
Anyway, for the radio, if the Kenwood is part of the chassis, then it would make perfect sense to run it off the chassis battery. You maybe able to rewire it to run on which ever source you like, but the radio has been the culprit for many who discovered to be the one that drained the chassis battery and need to jump start the engine or use BOOST button.
Either way the BOOST button saved my bacon several times, but now that I have the DC/DC converter I may have lost BOOST functionality.
