No Start - Fuel Pump Failure
Re: No Start - Fuel Pump Failure
Isn't it hard on the starter motor and engine to start it everyday and not running it for extends amount of time?
Kev,
Sounds like a leaking check valve. If you go to ignition position two, you'll hear the fuel pump cycle for a couple seconds. Do that a couple times before cranking. Might help. Good luck!
