House Battery Bank Wiring
TheIceKing
So we have a 2004 Summit 2700 with a 3-battery bank with a disconnect switch. However our local service center indicated that when the battery switch was switched to off, the battery bank still would deliver power to the coach. My questions I have is "does that seem like its wired correctly?" I would have thought that when the house battery switched to off, this should "kill" power to the entire coach.
Re: House Battery Bank Wiring
easy way to tell is shut off the battery switch without being connected to shore power and see if your interior lights work. if they do not work your coach batteries are isolated
TheIceKing
Noluck, thanks for the reply. I do understand that is a way to confirm the function, but my question I have is whether the battery switch's function is to kill all power to the house systems or should there still be some systems power at all times. We do have the original solar panel on the roof which should provide some battery charging when not connected to shore power, but I'm unsure if this will function properly if the house battery switch is turned to off.
Open to additional comments or thoughts.
It depends on what you want. My last camper the kill switch shut everything off other than the battery tender. This included the charger for the batteries. Basically I had to wait till everything was charged then flip the switch.
The kill switch may instead be an isolating switch between the coach and the chassis.
