Posted: October 21st, 2015, 12:22 pm
Manitou:
I'll read the link, thanks. I still don't think an AGM battery gives much advantage to Alan right now, but that doesn't mean not to buy one.
1) Looking at the diagram with the two solenoids, which does seem to match your rig, I don't think either of those solenoids is involved in your "house battery on off switch." Here is why I say that: You have three functions going on here. Two of them can be switched manually, and the other one is automatic (you don't see it, you don't control it, there is no switch).
A) Right solenoid (as looking from standing in front with hood open) is the one that manually combines your battery banks for jumping your own rig. That is the left switch on your dash, and the blue wire.
B) Left solenoid (as looking from standing in front with hood open) is the one that automatically combines and decombines the house and start batteries when you are driving or camping. Since it is not a "smart" solenoid (they go on voltage), I think it has a direct connection to the ignition and simply combines when engine is running and decombines when engine is not running. Which, if you think about it, should work fine. There is NO manual switch for this, I don't think. You don't "see" it at all, it just happens. This should be the purple/orange wire (as coming from under the hood and shown on diagram).
C) Mystery solenoid/relay (maybe the shiny Echlin?). This allows you to switch heavy cables (i.e. house battery cables) with a small switch (right hand dash switch). We don't know what color the wire is, but maybe yellow, since there is a yellow wire "floating around there" on the Chinook diagram?
So here are my guesses (and they are just that) based on what we now know (I've been keeping "score" on a piece of paper
First of all, to set the stage, my guess is that most people don't take a perfectly functioning system and start jury rigging it for no reason (now, granted, I did take out my perfectly good system and re-do it, but then I didn't leave ragged cutouts and loose wires dangling). So to my mind, something quit working properly, and someone did a bit of modifying. So I wouldn't be surprised if a solenoid or two are not functioning. Another possibility is that the PPO didn't like the fact that the Chinook "off house" switch actually still leaves some things live (detectors and etc.) and so put in a manual battery switch. But a little voice tells me the former is more likely.
My initial thoughts are these, addressing the loose wires under the dash (white/grey/orange/yellow).
1) Loose orange wire: I would have thought this connected to the ignition, in order to "automatically" combine or discombine house battery and alternator/start battery. Not to any visible switch.
2) Loose grey wire: Maybe this went to the solenoid (the Echlin?) that allowed a "small" switch to switch a big load (house battery power on and off to DC loads).
3) Loose yellow wire that now goes to positive battery post and is hot. I would have thought this also went to the solenoid (Echlin) and thence to the battery. Maybe in the "re-do" this was changed. I really don't think it can be correct to go from a 20 amp switch (right hand one on dash) straight to a battery that can be called on to deliver over a hundred amps.
4) Loose white wire: The ground wire for the original lighted switch.
Maybe you can test some of the wires "supposing" that the functions above are true, and see if they act correctly?
Supply = your 12 volt constant hot wire (but not directly to the battery!)
On/acc = to the switched device (maybe the Echlin solenoid that we are thinking does this?)
Ground = gets grounded (because light bulb needs its own ground).
Okay so to summarize. My guess is that some of your original parts (solenoids/relays) are broken. The manual battery switch was then added. So it may do one of two things. It may take the place of the left hand solenoid, and manually combine or discombine your house and start batteries (instead of the orange/purple wire we think went to the ignition). OR, it may be the "on/off/store" switch (that was the right hand dash switch) that either connects or disconnects your DC house loads from the house battery. Maybe you can figure out if it does one or the other and that will be a clue.
If any of this does or doesn't make sense, I'm happy to "dig" deeper with additional info.
Okay, so here is what I think. First a review of what we think we know of the original Chinook system.kyidletime wrote:Interesting! The newer solenoid on my rig has a grey wire connected to it, and the grey wire is also loose at the switches area in the dash, however, the left of my two older solenoids has a purple wire which changes to orange under the dash and is also loose. Like I have said, the loose yellow wire goes to the positive post on the house battery and is hot. I also have a loose white wire. So, in summary I have yellow, orange, gray, and white wires loose.
On the switch, I'm sorry, but I forgot to account for the fact that it is lighted. So the third terminal (ground) has to do with the fact that it is lighted. So here is how I would think you should wire it:kyidletime wrote:The three post switch that I have gotten is a 12v, 20 amp, single throw switch, the posts are labeled as: "supply volts", "on acc", and "earth ground". What are your thought as to which color of loose wires would connect to which posts of the switch.
