Chinook Concourse 2003 Renovation
Posted: December 21st, 2016, 8:08 pm
Greetings from Central Oregon!
I thought I'd start a thread describing the renovation of my new-to-me 2003 Chinook Concourse that I purchased last month. The rig has 63K miles and is in pretty good shape. I have no experience with such projects so I would appreciate any constructive criticism and advice. Any encouragement would be welcomed too.
- So far I have removed the jackknife sofa, the dinette, and most of the carpet. I will be replacing the jackknife sofa with a pullout, slat sofa that will be sufficiently sized for two to sleep. I will hinge the sofa near the wall so I can lift the sofa up to access storage and all the goodies underneath, like the freshwater tank and water pump.
- I have removed most of the carpet. Fun times. I will be replacing the carpet with vinyl flooring.
- I am not sure what I will be doing with the dinette area. I may build cabinets on top of the furnace for additional storage, put the passenger seat on a swivel so I can turn it around facing the living area, and place a small chair in the space opposite the furnace (nearer to the kitchen).
- Regarding the electrical system, I have replaced the tired, worn out old batteries with 2 Interstate AGM sealed batteries (125 amp hours each).
- I upgraded the charger/converter to the PD4645. I'm planning on upgrading the wiring from the charger to the LVD.
- I removed the batwing television antenna (leaving a hole in the roof for solar cabling) and the existing 50W solar panel. I just received (via AM Solar) the following: 2-100W panels, a Victron 30A MPPT controller, and a battery monitor. I'll be installing all this in the next couple of days. I've removed the driver side pilar to access the wiring space connecting the overhead cabinet to the battery bank. I'm thinking about dropping an extra wire from the solar controller down to the battery bank to give the option of adding a portable solar panel to the mix.
- Concurrently, I'll be wiring the weBoost Drive 4G-X OTR cellular boost system and a ham radio antenna. I'll be installing an ICOM IC-7100 ham tranceiver and the Comet SBB-5 UHF/VHF antenna. I'm working on an HF solution as well. I've read that an MPPT solar controller can interfere with the performance of a ham radio, so we'll see.
- I have already removed the VCR and television. We watch content on iPads and computers via downloaded videos when Wi-Fi is unavailable.
- I've already removed both of the ceiling vent fans (one in the main living area and one in the bathroom) and replaced one with a new Fantastic Fan, and will be replacing the other one soon.
- The local RV dealer replaced my rusted 19 gallon propane tank with a similar 14 gallon version.
- I'm also thinking about painting the cabinets a version of white.[/list]
I look forward to posting as the project moves forward.
