There may be another option for adding a quick outdoor shower capability to the Premier. One of these "pet" washer hoses could be attached to the kitchen sink fixture and run out the window for a shower option. Not sure if it screws on where the sink faucet attaches but there may be a sink fixture that works or an adapter available. Then there are no plumbing issues, and the window is right at the sink near the access panel where an outdoor shower would appear.
https://www.amazon.com/Master-Equipment ... B00GWVV4I8
The advantage is that the sink faucet already provides mixed hot and cold so you don't have to add hot and cold plumbing and a mixing faucet.
Adding an outdoor shower to a Premier
- caconcourse
- Senior Member
Re: Adding an outdoor shower to a Premier
The kitchen sink is too high for me to reach in to adjust the temperature.
- caconcourse
- Senior Member
I think you just set it and forget it before you go outsidechin_k wrote: July 8th, 2020, 11:47 am The kitchen sink is too high for me to reach in to adjust the temperature.
"Babe? Babe?! BABE!!!!!! Could you turn the hot water up a tad? OUCH!!! DOWN DOWN DOWN! Wait, up just a little."caconcourse wrote: July 8th, 2020, 12:19 pmI think you just set it and forget it before you go outsidechin_k wrote: July 8th, 2020, 11:47 am The kitchen sink is too high for me to reach in to adjust the temperature..
Just funnin' with you, caconcourse
2001 Premier aka "Anookie"
Dallas, TX area
Dallas, TX area
Oh, I want to be able to control it and not have to run into the rig with dirt on my feet, and dripping all over the floor if I need to cut the water, etc.
And FatBuoy, not everyone of us have such a sweet SO that baby us like yours do. I know my SO's favorite line is "If you don't like it, do it yourself!" She probably won't say that to me, but just shut off the hot water completely.
I think I will look into a remote control valves for the kitchen sink and Blue will have another item under my name for "why do anyone wants to do this?" category.
And done! I did end up disassembling the whole interior of the cabinet. No way could I have had the leverage I needed, to use the crimping tool, without doing so. Turned out great!!!
Dallas, TX area
Dallas, TX area
Very professional, as if Trail Wagons did it. The only thing that *I* will do differently is that I would use the two vertical PEX to connect to the faucet... I think the one running cross on the bottom is much longer piece, so I prefer not to have to play around with it in case I mess up, and need to replace the full length. The vertical ones are easier to access both ends, so it will be less risk. Anyway, since you did it without any issue, I guess my worry is not worth it. And I think it looks better the way you did it. Now I know whose door I need to knock on when I need to borrow the crimper
my 2000 concourse has that same set up
chin_k wrote: July 14th, 2020, 1:04 pm Very professional, as if Trail Wagons did it. The only thing that *I* will do differently is that I would use the two vertical PEX to connect to the faucet... I think the one running cross on the bottom is much longer piece, so I prefer not to have to play around with it in case I mess up, and need to replace the full length. The vertical ones are easier to access both ends, so it will be less risk. Anyway, since you did it without any issue, I guess my worry is not worth it. And I think it looks better the way you did it. Now I know whose door I need to knock on when I need to borrow the crimper![]()
You got it, Chin, and thanks! I was going to do that, but drilled the holes for the shower faucets first, and they didn’t align. I’m taking the crimper, and piece of PEX line with me in case I need to do field surgery.
Dallas, TX area
Dallas, TX area
If you pressure test the system by hooking it up to your house water, and see no leak, I think you should be alright without the emergency tool. Most plumbing issue happen without a few hours, so do that before you leave for your trip.
