Fridge acting funny, thoughts
caconcourse
Re: Fridge acting funny, thoughts
Post by caconcourse »
Sounds like the controller board. I would recommend the Dinosaur card for anyone with any fridge problems that still has the original card. It seems to be a much more robust controller.
sm350bl
Post by sm350bl »
Just ordered a Dino board. I will install that next week and re-test, give me a good opportunity to blow / vacuum the access area to the back of the fridge and make sure my vent is all cleared out.
Rich
sm350bl
Post by sm350bl »
I received the dino board and installed it this morning. I think at this point I will say this is a confirmed fix. Good instructions came with the board. I did have to make a new ground for one of the pins on the board but that was no big deal. Once install was complete I powered the fridge on and it came right to and auto selected AC and hasn't kicked off. Freezer was already down to 5 degrees and fridge down to 33 about an hr ago. I am going to let it run all night through tomorrow. The same time I ordered a new anode for the water heater since I didn't know when it was last done. Glad I did :lol:
old vs new anode
old vs new anode
added ground to junction
added ground.jpg (20.78 KiB) Viewed 45361 times
new circuit board
new circuit board
new board.jpg (15.54 KiB) Viewed 45361 times
original circuit board
old board.jpg (20.92 KiB) Viewed 45361 times
Rich
Looks like you got your money's worth out of the anode rod there! :D
sm350bl
Post by sm350bl »
chin_k wrote: March 16th, 2021, 1:50 pm Looks like you got your money's worth out of the anode rod there! :D
I am almost a 100% sure the original owner didn't know there was a sacrificial anode that needed to be changed out annually. Luckily the water heater has low hours on it so there wasn't a ton of water flowing through it. I used my water heater wand and de-scaled the inside of the tank. Did get a fair amount out of it but i am hoping no real damage occurred. Hey at least there is a fresh rod in it now. I have never seen one that didn't have SOMETHING on it :lol:
Rich
That thing was toast. :lol: Glad to hear the fridge is working.
FYI In case it wasn't ever done there was a safety recall on Dometics that is free of charge at any authorized Dometic dealer. You can tell if it was by the sheild installed around the flue area.
sm350bl
Post by sm350bl »
SMan wrote: March 16th, 2021, 7:56 pm That thing was toast. :lol: Glad to hear the fridge is working.
I am happy to report that the fridge has been working continuously for almost 24 hrs now.
Thanks for the heads up about the recall campaign, This is what my flue area looks like. Is this the recall shield?
Rich
I can't see the attachment... need admin help, or it is my issue?
Edit: Nevermind. The pic shown up after a few seconds. It looks like the one that has been installed. I would check the label on the shield to make sure it has the updated label. Anyone else who can confirm will be good (I just do this from memory of what mine looks like.).
Yes that looks like the shield. I remember somewhere there was a before and after picture but I'll be danged if I can remember. I think I googled it.
Ideally, we should confirm the recall upgrade by calling Dometic. They keep the record of which rig (VIN) has the recalled performed, by whom, and when. There should be label on the shield, but I am not sure. If in doubt, get it from the horse's mouth :D
