Diesel conversion
kj47hunter
Re: Diesel conversion
Post by kj47hunter »
Did you ever get around to doing the 7.3 swap in your 97 Chinook? Looking to do the same and would be great to learn from someone who did it 😉
JabberBox
Post by JabberBox »
Theres a company called MGmetalworks, they installed a cummins engine with an allison transmission and four wheel drive on a later model E-350 extended van. You should try that instead.
markatherton
Post by markatherton »
I ended up buying
a 2000 concourse with a 7.3 diesel. I then converted it to 4x4. I love this vehicle and they will probably bury me in it. I sold the 97 side entry.
Chinnin-about
Post by Chinnin-about »
Mark, your coach looks great. The aluminum wheels, the redone graphics, the stance...
Ever thought of replacing the refrigerator grate?
markatherton
It is on the list...
robertosorio
Post by robertosorio »
mark. quick question. did you like your side entry over your current back entry? if you could choose between both with 7.3 what would you go through since you have had experience in both? thanks again for your time .
