For the section behind the plywood divider, where the fridge and closet were, I decided to try out a wall of shallow cubbies. Behold, prototype from big-box flatpack:
It's screwed to that plywood divider on the side, and also into the few bits of wood along the back wall, under the carpet and around the back of the fridge. I also filled the bottom row with heavy stuff - bottled water and tools. I added large-ish cup hooks to either side and ran a bit of rope across each row to prevent the bins sliding out. It is not a long-term solution, but it worked reasonably well for a few hours' driving and let me try this idea without stuff crashing around when I go around corners.
This is a very successful prototype, IMO.
- It provides a ton of useful storage, organized but easily accessed. I still had empty bins in the top row at the end of a week-long trip!
- It gives me elbow room (and butt and shoulder room) when coming in the back door, putting coats on/off, leashing up the dog, drying off after a shower, etc.
- The top of the cubbies and the exposed ledge of the generator compartment provide a little drop space for setting things down temporarily.
So, now I know what I'm building out, it's time to finish the destruction! I took out all the temporary shelving and have started tearing out the carpet. The main walkway came out reasonably easily, apart from the bit glued to the steps, so I'm down to arguing with the sections that have electrical or propane lines punched through them, which i have to cut around. Then new wall surfaces will go in and I'll start building the permanent (ish
