I've been told I need to reset the inverter and that it's yellow and grey. I found what I thought to be an inverter. It's the blue on with fins in thew door under the wardrobe. Apparently that's not it.
Before I start unscrewing panels, could someone please tell me where it is on the Glacier?
Glacier Inverter Location
2001 Premier aka "Anookie"
Dallas, TX area
Dallas, TX area
Re: Glacier Inverter Location
The Glacier inverter is located on the floor under the tall wardrobe closet. It is behind the 120 volt distribution/fuse panel. You access the inverter by removing the floor of the tall wardrobe closet.
Glaciers came with one of two different model inverters. Zantrex Prosine and Tripp Lite.
That Blue with fins unit is the LVD (Low Voltage Disconnect).
Once again- thank you.ltg wrote: May 2nd, 2022, 7:51 am The Glacier inverter is located on the floor under the tall wardrobe closet. It is behind the 120 volt distribution/fuse panel. You access the inverter by removing the floor of the tall wardrobe closet.
Dallas, TX area
Dallas, TX area
