Q. on installing new front roof vent
Hi, I decided to replace the original Fantastic Vent in the front of my 2001 rig. I am going with the Hurrventer Roof Vent with Remote and using Butyl Seal tape and Dicor Non-Leveling Lap Sealent.
My question, since the original vent has been in place for 24 years is there anything I should be particularly concerned or cautious about while removing the old unit? It seems pretty straight-forward but on something that old you never know what you run into.
Thanks in advance.....
Chuck
noluck
Re: Q. on installing new front roof vent
Post by noluck »
the only thing i found when i replaced mine was some of the holes were not in the same spot. so pre drill the ones that might not line up. other than that it is straight forward
Blewett
Post by Blewett »
I didn't have any problems removing mine or installing it. As noluck said the holes may not line up. Removing all the gunk and prepping the surface was the most annoying part.
Thanks all!
