Ford Serial Number Decoder Guide
Dano
Post by Dano »
Here is a great link so you can decode your VIN number if desired:
https://www.fleet.ford.ca/resources/for ... IN2002.pdf
Re: Ford Serial Number Decoder Guide
The link does not work due to format issue .... I should have download it and save it as file. Dano, can you edit the link and get it to work again?
This is where I find a file.... do not know if it is the original one from Dano.
https://www.fleet.ford.com/content/dam/ ... IN2002.pdf
VIN2002.pdf
(362.37 KiB) Downloaded 637 times
