EGR valve and throttle body
jhnzstrng@gmail.com
Post by jhnzstrng@gmail.com »
I've got a 2001 Destiny with a 8.1 liter Chevy 3500. My mechanic says I need an EGR valve and throttle body but can't find one anywhere. I know nothing about engines but am reaching out if anyone has any ideas? We're in Morro Bay, CA.
Re: EGR valve and throttle body
I've never touched that motor before, but is it not just as simple as looking it up on a parts store like rock auto?
https://www.rockauto.com/en/catalog/che ... motor,4380
M_MINCEY
Contact:
Post by M_MINCEY »
Is this a 2001 Chinook Destiny 2400? Built on the Chevy 3500 chassis with the VORTEC 8.1L V8 engine?
jhnzstrng@gmail.com
Yes it is. The part number is 88894094 or 2141058 according to the mechanic.
noluck
Post by noluck »
do you have to smog test the chinook? if not i would do a delete kit.
noluck
Post by noluck »
2003 was the last year they used a egr in the 8.1
jhnzstrng@gmail.com
Yes I have to smog test it. :( I like the thought though. Thanks
noluck
Post by noluck »
upgrade the ecm tune to 2004 or newer, better smog numbers and no egr
M_MINCEY
Contact:
Post by M_MINCEY »
Hi,
I did some additional research because I have the same engine as you but my rig is a 2002 Chinook Destiny 2400. Which I believe has the same engine as yours the "Chevy 8.1L Vortec Engine". The Part Numbers you provided 88894094 or 2141058 are no longer manufactured. That being said the Exhaust Gas Recirculation (EGR) valve for the 2001-2004 Chevrolet Silverado 3500 8.1L V8 engine maybe the same part. I spoke with The Parts Geek (800) 541-9352 and they believe this part will work for you:
https://www.partsgeek.com/98tg1mq-chevr ... valve.html
He also suggested to call ACDelco (800) 223-3526 and cross reference the parts numbers you provided. To see whether or not is there another alternative that would work as a replacement.
Regards,
