Your thoughts on purchasing an early 2000’s Chinook?
DRC
Post by DRC »
We’re considering purchasing a 2004 Cascade, but are a little nervous about reliability with a 20+ year old rig. Service records indicate it has been well maintained for the past 5 or 6 years and mileage is sitting at 95,000K.
Wondering what those of you who have similar rigs might have to offer as thoughts or advice?
Thanks!
Re: Your thoughts on purchasing an early 2000’s Chinook?
In 2018 I purchase a 2001 Concourse with 71k miles, currently have 115 - 120k. It has the V10 and I have had zero issues with engine. I heavily upgraded suspension to get off-road. The V10 is a beast of an engine and we expect many more miles. The biggest issue for us was needing new tires and upgraded brakes, both of which we did immediately. I did not like the E-350 standard brakes - especially going downhills. Also, if purchasing get roof resealed or do yourself, its cheap and or easy and will prevent water damage.
Everone's rig is different but we have been blessed.
I agree with 68 Camero that the 6.8 liter v10 is a beast of an engine. It will run all day at 75 running only at 2500 rpm’s. Brakes, shocks, tires…that’s usual wear and tear. It is suggested that you install new plugs at 90,000 miles. Batteries/charging—depends on what you have and what your intended uses are. As for other things—over time, I have replaced water heater ( leaked), and water pump (worn out seal). Also new vacuum reservoir for AC, and I am currently feeling with a small leak in the ac evaporator coil that will probably need replacing ($3300 job). And roof top AC unit has stopped putting out cold air. I tried the easy fix of replacing the capacitors to no avail—these units can not be recharged, so only real choice is to forego AC or replace the unit.
Bottom line for me: Chinooks are worth keeping…but you should expect to spend some money over time to keep a 21 year old vehicle up and running.
