MORryde Rubber Suspension
Here are the Installation Instructions and Owner’s Manual for the MORryde RL rubber shear spring suspension. Note these have a three year warranty.
- Attachments
- MORryde_Manual.pdf
- (1.05 MiB) Downloaded 1132 times
- MORryde_Installation.pdf
- (7.63 MiB) Downloaded 1123 times
Re: MORryde Rubber Suspension
Mine are bonded, but I think there is a "10" molded on the side, which is not listed. I will clean the rubber side and take a picture. It was dark when I went outside to check the number last night.
[Edit]: Actually, they are bolted in the middle.
Here is a video on youtube that maybe useful for some of you.
https://www.youtube.com/watch?v=lSrPLDfEJuU
Re: MORryde Rubber Suspension # DSR108-075
A document about the install of the DSR108-075. The bonded, no bolts for center plates type.
I've also begun a renewed discussion over viewforum.php?f=4 section of this forum. if the link doesn't work, it's the "Projects / Known issues" subsection.
Best,
MSH
Best,
MSH
- Attachments
- RL-Owners-Manual.pdf
- (996.19 KiB) Downloaded 748 times
- DSR type of RL spring is DSR 108-075.pdf
- (448.13 KiB) Downloaded 838 times
All Together Now, Everybody!
