I have been doing some reading preparatory to buying and installing a rear-view camera. Haven't done so yet, but a few things I have gleaned:lankylady wrote:I have a 2003 Concourse ... how tough is it to install a back up camera in this unit?
1) It's not that hard, just a bit fiddly/time-consuming figuring out how and where to run the wire(s) and then doing it.
2) There are "wireless" cameras, but they may not be as wireless as you think (they still need power, etc.), and they are not as "bulletproof" as wired ones (but they are getting better).
3) Typically these cameras are activated by putting the vehicle in reverse, but as an RV-er, you may prefer to have it on all the time (or at least have a switch so you can turn it on whenever you want). I will do the latter as I mostly want to be able to use it when towing, to keep an eye on the trailer.
I have read many recommendations for this e-Bay seller and his cameras. I think I will buy one of these, likely the 5" or 7" display (not sure on that yet). (But there are many other good cameras/sources, I'm sure.)
http://www.ebay.com/usr/leviathan_holdi ... 1438.l2754
